jaws4518
Cold Beer
- 221
- 121
- 43
- Abilene, Texas
Thought I would ask for diagnoses advice, but I will search the forum for any threads related to possible cause for excessive heat difference on one hub. My right rear hub is much hotter to the touch others. All others are normal. At this time I have the axle removed, ready for the inspection of bearings, brakes etc... At first glance, everything looks o.k. on the inside with axle removed. Going to start inward in a few minutes to see if I find anything unusual. Got this truck with 17 hrs on it. The best deal in my lifetime. It was referbed in 2010. As far as I can tell everything is pretty much factory fresh. Engine started breaking in at about 35 hrs. Probably topped out at 60 hrs. I've got 83 on it now. Needs an oil change.
Anyway, just working down a list of things that need to check out or fix after 80 hrs of break-in. Noticed that the right rear hub was running hot to the touch. Maybe a brake pad dragging?
If anyone has and suggestion please sound off. I'll check back in awhile.
