mattsb2000
- 0
- 1
- San Bernardino CA
My friend bought a M998 and has been keeping it at my shop. I drew this up and plasma cut it. It's simple and it keeps people from starting it.
Only if you know how to go around the neutral safety . Or am I missing something?It will still start.
Sent from my SM-T560NU using Tapatalk
Agree with youOnly if you know how to go around the neutral safety . Or am I missing something?
Neat idea!My friend bought a M998 and has been keeping it at my shop. I drew this up and plasma cut it. It's simple and it keeps people from starting it.
Sure it will if you climb under it.It will still start.
How would you do that? Get it rolling in N and then put it in drive? Or physically have it pushed in drive? Would that even work well?I agree about the cable lock. Having driven Humvees for almost 23 yrs. I always thought it was useless. Easy to cut. As for starting. Unless you have installed a keyed ignition or battery cut of switch. Since transmission doesn't have a park brake, it can be push started in gear.
How does one push start an automatic tranny?I agree about the cable lock. Having driven Humvees for almost 23 yrs. I always thought it was useless. Easy to cut. As for starting. Unless you have installed a keyed ignition or battery cut of switch. Since transmission doesn't have a park brake, it can be push started in gear.
Post a video of this please.Leave it in drive, it's not like a manual transmission where you pop the clutch . Another way of jumping it off. Pain but works unless there is no power to the ignition system.
I should probably take the sling points off of it as well. Never know when a rogue helicopter pilot might come by.Also lock being used can still be cut with bolt cutters.
Unless you can demonstrate that you've done it, I'm calling bulls hit on this one...Leave it in drive, it's not like a manual transmission where you pop the clutch . Another way of jumping it off. Pain but works unless there is no power to the ignition system.
