M35A2C 15A Breaker
502NDMP
NH
I need the wire numbers and their locations to install this under the dash on the drivers side. I did have all the schemtics and the TM, but lent them out. Need to move truck in the next two days, no time and patience to look up all the info again. Please, any help, would be greatly appreciated.
texas30cal
87
Brenham Tx.
Isn't it mounted under the hood on the firewall near where the main harness passes through? There's a CAD wiring diagram in the sticky section
1,158
I've never seen one under the dash. There are 4 pre-drilled holes on the engine side of the firewall above the steering column.
See:
502NDMP
NH
No, this was mounted under the dash, inside the cab against the firewall about 3/4 up from the floor about inline with the gas pedal area. This is a M35A2C, my other M35s, show the mounting position shown in your photos. Thanks for the photos, always very helpful! I printed up the CAD, but lent it out and can't really read the layout on my computer and I do not have printer access presently.
doghead
4 Star General /Moderator
1,191
Why are you wanting to replace it?
What does not function?
Do you see 2 wires that would reach where it was?
rustystud
3,372
Woodinville, Washington
I have a M35A2C and mine has it mounted on the firewall in the engine compartment. It powers the horn.
