Howdy,
This is just a information post.
A MEP-813A 10kw 400Hz generator does not work for a normal household.
It produces 400Hz power. Which means you could start a aircraft, or run a radar system.
In the civilian world, you could call it a expensive boat anchor
A normal USA household uses what's known as 120/240 volts 60Hz power.
There is no easy way to make a 400Hz generator work for your house.
A MEP-813A generator is useful for miscellaneous parts. Door panels, body panels, pumps, radiator, engine only, some gauges.
For all those new people buying a surplus generator. I hope this helps when you look up what a MEP-813A generator is.
If you are looking for a unit which works for your house? a MEP-803A 10kw 60Hz generator is the name.
NOTE: you should become a member here on steelsoldiers.com for all your generator information.
