I have looked and used google and can not find any write up on this. My hmmwv a '93 with the 6.5L and 3spd in it with 32k miles. Last friday i was driving it and all of a sudden the engine started surging. Almost like it was sucking air and loosing fuel. as i was attempting to limp it home i noticed that it idled great and up to about 35 ran fine. as i was driving more it started loosing speeds and would not hold a 55mph speed. I got it home and in neutral would hold rpm's with out an issue. I checked the water fuel separator and no issues. i checked the fuel filter and no issue there either. I then noticed a large amount of vacuum when removing the fuel cap that day when filling up. I pulled it again and sure enough it had what i would consider a large amount of suction. After i put the unit back together she ran great. Put about 50 miles on it running around town and a few back roads to hold it at 55. No issues to report there. got home and pulled the fuel cap and had a vacuum again. so then sunday i decided to give it the good college try since it seemed to be running fine and we took off to a family member's house. ran like a champ headed down. coming home however it started acting up again and we limped it home. it did die on me when pulling up to a stop twice. It had issues getting over 35 and holding it. One thing i did notice was after i killed it and restarted the unit it would run fine for a few miles. Any advice or help.....
Thank you
Larry
Thank you
Larry
