- 1,394
- 176
- 63
- Frisco Texas
Did I miss the first test run of the engine?
Where will it live for the duration of its change out?
What shall we call it while it’s going through it’s change, and at what point is it fully ... you know, “changed”. I don’t want to offend it.
Before you you do the change out are you going to run a series of tests? 0-60, or 0-50 in my case. (My test road was too short). There is an app called speed box that I am installing in an iPad mini as a backup speedometer that has a bunch of tests that you can run and do before and after tests.
You really should try it out! We want to know! Even if you just wait until you figure out how to drive it, that’s fine. I’m still very curious.
