heavyzee
- 1
- 6
- Houston, TX
Won a powerplant that has 2 802a's on it. and i can't get either to crank... Both of the Crank Relays are dead
I have searched everywhere including green mountain generatrs, to no avail for finding this part.
It is a Eaton SM50D8
Anyone know of a source?
In order to diagnose this, i did the following, and just about posted this before i figured it out the crank relay was bad.
I have downloaded and read through TM 9-6115-641-24
Followed troubleshooting procedures outlined in 2-8 ENGINE FAILS TO CRANK. Steps 1-20
The starter will crank over if solenoid is jumped, and will turn over the engine with no issues.
Observations:
Starter Relay Clicks
no fuel pump noise when turned to prime and start (but all the relays work properly when tested on the bench)
Preheat relay clicks when master switch is turned to preheat
Units have fuel
Units have nice black oil in the case at appropriate level
Units have fresh coolant at the appropriate level
Engine will turn over with jumping the solenoid
Dead Crank Switch will not turn over engine
I have known to be a dumbass in the past and overlooked the obvious...![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
Thank you for your help in advance
-Z
Observations:
Units have fuel
-Z
