Ecscnvb
- 1
- 0
- Va beach/va
I know it says not to do it but I've also heard if the front axle is disengaged then it is ok. Opinions please...
Sent from my SM-G935V using Tapatalk
I've read the threads. I want to know why disengaging the front axle makes it ok. Is the weak link of the transfer case up front? What is it? None of the other threads get into depth and specifics like I want to know.You can do it if your careful or dont do it at all
Along with the countless threads on this matter
Sent from my SM-G935P using Tapatalk
Never hear that but it is less stress on the case. You should not need low range reverse anyway. It has plenty of power in high range to push most stuff around. In offroad applications you would rather have the wheel speed over torqueI've read the threads. I want to know why disengaging the front axle makes it ok. Is the weak link of the transfer case up front? What is it? None of the other threads get into depth and specifics like I want to know.
There are times I've been stuck in high, put it in low and pulled right out. So I would have to disagree.Never hear that but it is less stress on the case. You should not need low range reverse anyway. It has plenty of power in high range to push most stuff around. In offroad applications you would rather have the wheel speed over torque
Well then thats you some folks dont feel the same way. I cant even use low on my transfer case cause it will end up in pieces i am sure.There are times I've been stuck in high, put it in low and pulled right out. So I would have to disagree.
Can tell u first hand it won't end up in pieces. Anyway, y have something if it can't be used. That's y I wanna figure out the reverse situation. I use my **** hard like it was built for.Well then thats you some folks dont feel the same way. I cant even use low on my transfer case cause it will end up in pieces i am sure.
A2 Trucks dont have the low rpm power that an A0 or A2 has so they need rpms to get the tires up and moving.
My application will end up in pieces sir. My 1st, 2nd and 3rd forward and Rev 1 are all lower ratios that the allison reverse.Can tell u first hand it won't end up in pieces. Anyway, y have something if it can't be used. That's y I wanna figure out the reverse situation. I use my **** hard like it was built for.
What truck do u have?My application will end up in pieces sir. My 1st, 2nd and 3rd forward and Rev 1 are all lower ratios that the allison reverse.
They arent meant to be abused. They did a lockout on these units for a reason as the case can not be serviced and internal parts are hard to come by. It may be military grade but it doesnt mean it was the best or strongest design.
A 923A0 as it was built.What truck do u have?
Gotcha. I'm talking about an m923a2 and low range reverse as it pertains to what the truck is built with. Of course ur application is different, u modified it and it wasn't an m933a2 to begin with.A 923A0 as it was built.
https://www.steelsoldiers.com/showthread.php?t=169592
Its still an NHC250 a1 truck. In an A0/1 truck they put power to the ground faster and more of it imo. So like i said an A2 doesnt have the low end rpm torque in high range. Such as it cant break the tires loose on wet grass. So yea using low range may not hurt you to get better rpms but one day it might get you. I didn't see that you stated your model truck in the opening post. Just that why can't you use low rangeGotcha. I'm talking about an m923a2 and low range reverse as it pertains to what the truck is built with. Of course ur application is different, u modified it and it wasn't an m933a2 to begin with.
Thank u. Do u have the washer off the low range linkage or is ur front axle still engaged?I had a CWO in charge of a Army Maintenance Facility tell me putting it in reverse and backing up is fine, as long as you do not have it under much load.
The transfer case cannot handle the increased torque, and it’s the reverse gearing that has the most torque.
He recently retired after 33 years in Army and really knew his stuff on 5 tons.
I use low reverse all the time.
But I’m always only backing up short distances on loose soil/gravel, not trying to pull out a tree, etc.
Well power is not a problem for me, as I'm about to do some serous mods. Tranny and transfer case will be shortly after. I just want to know what the weak point is.Its still an NHC250 a1 truck. In an A0/1 truck they put power to the ground faster and more of it imo. So like i said an A2 doesnt have the low end rpm torque in high range. Such as it cant break the tires loose on wet grass. So yea using low range may not hurt you to get better rpms but one day it might get you. I didn't see that you stated your model truck in the opening post. Just that why can't you use low range
Still engaged.Thank u. Do u have the washer off the low range linkage or is ur front axle still engaged?
The case. With the gear behind it. Ive busted em in high and low range. Forward and reverse. There is no pattern.Well power is not a problem for me, as I'm about to do some serous mods. Tranny and transfer case will be shortly after. I just want to know what the weak point is.
Good to knowStill engaged.
I could break it tomorrow, but I’ve been doing it for 3 years now without issue.
