rustystud
- 2,853
- Woodinville, Washington
I just wanted to post some warning pictures of the damage hammering on the "pitman" arm can do. Also hammering on the drag-link can cause the same damage. Always use the right puller when removing the steering pitman arm or drag-link. This steering shaft came out of one of my 1952 REO M35 trucks. I'm working on a power steering project and needed the housing. I just torched off the pitman arm as I didn't need it, but I could see the evidence of hammer marks on it. After I cleaned up everything I saw this damage to the screw threads on the shaft. You can see the metal has actually cracked and broken off in places. The steering still worked but always had a tight spot. Now I know why. Eventually the broken metal would have come off and could have caused total steering failure. Jamming the sector shaft. Not a good thing to have happen especially if driving down the freeway !
