- 1,172
- 24
- 38
- Nashville, TN
There’s something like 12-13 oz of gear oil in the front ones. I doubt “dry out” is a factor unless there is another problem with a seal or excessive heat from bad bearings.How fast do they dry out?
Sent from my SAMSUNG-SM-G930A using Tapatalk
FYI. The rear hubs are lubricated by, and share the oil in, the entire differential and axle housing. Oil level there is also very important, but not as critical as the front hubs since the reservoir is gallons not ounces.
