I did mine with red led's
got them at
https://www.superbrightleds.com/
one thing you might want to do is paint the inside of the bezel. you will find the old bulbs have burnt spots in the bezel. I painted mine a reflective silver but I think white would have done just as well.
don't change the gen lights.
Led's wont dim without a special dimmer and the bulbs also have to be capable of dimming. if you figure all that out then please post it.
The red led's I used do not need dimming. they are perfect for my liking.
I am using a civy cluster set up with gauges so it is not the stock cucv cluster and I have moved things around but that does not really change anything with the LED's I am still using the printed circuit board and the stock light bulb locations in the cluster.
you can search my post. I never got to complete my wiring diagrams so if you run across any that I posted, be ware of errors. you don't need the wiring info to just change bulbs.
good luck
Rich
