converting geared hubs to 12.1k gears
kmalcom
kentucky
I am wanting to replace the input gears for my hubs to the 12.1k style. Do the lower dears have to be replaced too ?
thanks
kmalcom
kentucky
ok great... on the lower gears there are two different part numbers also. If I needed to replace one of those should I go ahead and get the 12.1k gears ?
Retiredwarhorses
4,528
Brentwood, Calif
12k has 2 lower gear part numbers because there are straight cut gears and Helical cut gears.
only the late style use helical cut, you can just use what's already in there, no need to change them.
the lower gear is no diff, it's the upper gear that changes.
