Low air buzzer
Kharville
Clinton LA
Went out to see how the Deuce would start in our first cold weather here in the south this morning. Started perfect with a few more turns than usual but 3-5 seconds total with no assistantance.
I went back inside to let it warm up and when I came back out air pressure was normal but low air buzzer was sounding faintly. Does that buzzer ever get stuck in anyway? Pressure was 90-120 and brakes were good. It was about half volume of the usual BUZZZZ. :)
porkysplace
1,496
mid- michigan
Have you been draining your air tanks regularly ?
If not there may be ice in the switch making it stick , it should go off completely over 60 pounds.
