HMMWV Pioneer Tool Rack
70deuce
121
Franktown, CO
For all of you who are curious how the pioneer racks mounts up under a HMMWV here is what it looks like. Just received and installed a brand new pioneer rack on the M998. After the tools are secured to the rack it takes less than 30 seconds to mount and secure it. Highly recommend adding some sort of safety pin in the latches. They do lock into a groove on the locking handle but not very well and I can see them springing open under the right conditions. All the traditional pioneer tools fit nicely in the rack and it tucks up nice and tight behind the rear wheels. Obtained from an Ebay merchant for a very reasonable price.
1 Patriot-of-many
87
Zimmerman MN
What keeps the rack from sliding toward the front and bouncing out of the bracket? Just want to make sure I just slide mine into the bracket, nothing else on the bracket? Thanks.
NormB
115
Hampshire, TN
There're two upright tabs at the rear of the rack aligned with the straps. They're clearer in the second photo. These go up and behind the bumper when the clamps are shut and prevent the rack from sliding.
Duster06
Virginia
I just got one of these from my brother as a Christmas gift. I don't have a bumper yet. Every bumper that I see online for sale doesn't have the clips installed on it. Does this require drilling?
juanprado
3,120
Metairie/La (N'awlins)
on the air lift bumpers, the catches are on the braces and not visible from outside. The rack needs a different 45* bracket for the latches which kascar sells.
Do you have the original rear slightly curved bumper or the upgraded flat MWO towing upgrade bumper?
Either one of those should also mount the catches to use with this tool rack.
Post pics of your bumper and tool rack at the latches.
Cobra38
NC
The round rubber bumper stops on mine don't hit the bottom of the bumper after latched. Adjusted the latches all the way in and they still don't contact so everything just hangs loose lol. Guess I need thicker/new round bumper stops.
juanprado
3,120
The bracket mounted on the frame cross member is slotted. Try loosening those bolts and adjusting?
ElKapetan
Lancaster, OH
[FONT=&quot]Hi! Just finishing adding airlift bumper to my A1, and can't seem to get the darned shovel to fit in the pioneer tool kit without hitting the bumper frame members. Standard Army shovel, tool rack made for the airlift--but no matter how I adjust the shovel, the curved blade hits the bumper cross members when I try to latch the rack. Has anyone hit this snag? Are there detailed drawings showing all the different tool rack configurations to see if maybe I just have the wrong rack?[/FONT]
90Jimmy
Southern Illinois
Pic...then we can see what you got.
ElKapetan
Lancaster, OH
Just finished adding airlift bumper to A1, now can’t get shovel to fit. Shovel blade hits the diagonal bumper braces and frame when I try to latch the rack, can’t find good pics to show how supposed to fit. Using newer rack for Airlift, standard shovel. Any suggestions?
90Jimmy
Southern Illinois
I think bikeman is correct. The handle of my shovel fits inside the bracket your shovel appears to sit on the outside of. I’ll get a pic up when day breaks around here.
