FMTV Truck Sales
- 12
- 18
- Belgrade, Montana
Hello all-
We currently manufacture a replacement keyed ignition switch and a civilian headlight switch for our Acela Monterras (some photos attached).
The ignition switch is pretty much plug and play...maybe a 30 minute install that requires drilling out the existing starter button hole and prying two connectors from their plastic housing.
The headlight switch is also very quick and easy to install and plugs directly into the OEM amphenol Master Vehicle Light Switch (MVLS) connector, and requires a single 12VDC connection. The headlight switch kit would provide blackout delete (so nobody ever inadvertently drives your truck without brake lights!) and also provides dash illumination dimmer and dome light control leg. A direct fit mounting plate would be provided as well.
Both will work in any A0 or A1 truck, with any style MVLS or with/without factory dimmer switch.
Is there any interest out there to purchase as DIY kits?
Thanks for your input!!
