10Lugger
- 5
- 18
- White Post, VA
![](http://uploads.tapatalk-cdn.com/20180106/6b8c2ccb3a289bf297c9a3a0dc89d85d.jpg)
![](http://uploads.tapatalk-cdn.com/20180106/760ef84a0fbeb88ad98732d01225d537.jpg)
![](http://uploads.tapatalk-cdn.com/20180106/6d6766319979041d975c8f099cc9afdb.jpg)
I had to order o-ring and still waiting on it, but I reassembled and seems to be holding for now. I just don't trust the o-ring.
The check valve kinda protruded out as I took the cap off, due to a little air still in tire. I just grabbed with my fingers. Below is a picture of parts after cleanup and putting a small piece of rubber between valve and union.How did you get the inner portion out? I was able to take the cap off but that's it.
Sent from my SAMSUNG-SM-G930A using Tapatalk
UPDATE: OOPS ignore rest of post below....... my bad. see you did just that in your first post so suspect you will do it with above post as well.The check valve kinda protruded out as I took the cap off, due to a little air still in tire. I just grabbed with my fingers. Below is a picture of parts after cleanup and putting a small piece of rubber between valve and union.
[IMx]//uploads.tapatalk-cdn.com/20180106/6b8c2ccb3a289bf297c9a3a0dc89d85d.jpg[/IMG]
[IMx]//uploads.tapatalk-cdn.com/20180106/760ef84a0fbeb88ad98732d01225d537.jpg[/IMG]
[IMx]//uploads.tapatalk-cdn.com/20180106/6d6766319979041d975c8f099cc9afdb.jpg[/IMG]
I had to order o-ring and still waiting on it, but I reassembled and seems to be holding for now. I just don't trust the o-ring....
Picked up elbow today, looks like the other two on the truck. I didn't install yet because I wanted to see if suspected o-ring was the culprit. So far tire is holding air after O-ring change out. If not, I'll change out elbow, but at least I have one on hand. Thanks to all that participated.The Dana part number for the regular elbow is 673240, a truck part store should be able to order them for you.
uploaded the pics for archiving.Picked up elbow today, looks like the other two on the truck. I didn't install yet because I wanted to see if suspected o-ring was the culprit. So far tire is holding air after O-ring change out. If not, I'll change out elbow, but at least I have one on hand. Thanks to all that participated.
uploading pics for archiving. Post 21 and 22 are same picsThe check valve kinda protruded out as I took the cap off, due to a little air still in tire. I just grabbed with my fingers. Below is a picture of parts after cleanup and putting a small piece of rubber between valve and union.
I had to order o-ring and still waiting on it, but I reassembled and seems to be holding for now. I just don't trust the o-ring. See pics above....
