Did a mock up for my hydraulic jacks for the tongue on my M322. The replacement jacks I put on a few months ago are just a little short. Blocking up is ok but when the trailer is loaded or has anymore than it's normal 1800lbs of tongue weight it gets to be a chore to get it off the truck. I am going to use the mine roller hydraulic unit that I am going to run to install my hydraulic ramps to run the tongue jacks as well.
Going to go with two 3" diameter 30 " stroke cylinders that should be able to handle up to 20,000 lbs easily. Luckily I have them laying around.
The mine roller unit runs off a standard 3way controller and operates via a slave port connector. So I will have to run some wires to the rear of the truck and install a slave port on the rear frame someplace. It looks good on paper and for mock up at the moment.
