MEP-831A SLC100 Governor Controller Replacement Prototype
kloppk
4,205
Massachusetts
Latest PCB's just received. Populated one and tested it in one of my 831's.
Couple of firmware tweeks to do to perfect performace, but looking good!
kloppk
4,205
Massachusetts
OK, units are now complete and ready for shipment.
See link in signature for classifieds listing to order.
dav5
203
Mono, Ontario
IMG_0796.jpgIMG_0794.jpgHi, I have been totally frustrated with new controllers I bought from GAC. I sent one back and got a replacement which worked fine and had the same thing happen on a second controller so I asked for a refund and ordered 2 controllers from Kurt. The cost for 2 controllers was only about 2/3 the cost of one GAC controller. I installed one today and ran it with a makeshift 3kw water heater load bank. I had messed with the magnet when I was fiddling with the original controller and the machine was surging every 10 seconds or so at idle and not shutting down properly. I adjusted the magnet so it would shut down and the idle problem disappeared. I created the problem it was not the controller. The controller works great. It has smooth acceleration and deceleration and no smoke in the exhaust whereas with the original controller the constant surging created lots of black smoke. My only criticism and it is very minor is that the letters under the terminals could be bigger and lower down so you can see them better. Thank You Kurt for your efforts.
Ted
kloppk
4,205
Massachusetts
... My only criticism and it is very minor is that the letters under the terminals could be bigger and lower down so you can see them better...
Ted - Thank you for the improvement suggestion. :roll:
I too noticed the font was a bit small too.
I revised the design and incorporated a larger font size for the terminal lettering. Those new PWB's just arrived this weekend.
At the same time I ordered all the parts to build the next batch of controllers.
But.. some scumbag stole the box's of parts from my mailbox as well as another package before I got home Friday. aua
profo
75
jeanerette,la
Having purchased a couple of MEP-831A's I found that the SLC100 Governor Controllers are problem prone. The two Tier 2 Reset units I purchased with just 2 hrs on the clock both randomly exhibited surging issues as well as random WOT issues. Adjustment of the SLC100 Governor Controllers was futile.
I dropped about $350 on a new SLC100 from GCA to repair one of my 831A's and knew there had to be a better solution than dropping more than 50% of a 831 purchase price on a new controller!
Being a retired DOD engineer and not not being satisfied with the analog, moisture prone design issue of the SLC100 I decided to design a replacement for the SLC100 governor controller for the 831A. After studying the TM, the tuning procedure and the operation of the SLC100 I came up with a design that eliminates the primitive analog feedback system employed in the SLC100 with the four moisture prone potentiometers.
Operational description:
The SLC100 takes two inputs to determine the appropriate setting of the engines throttle actuator. The first is the frequency from the PMA (engine RPM) and the second is the %Load applied signal from the inverter. The SLC100 operates to adjust the voltage to the actuator so that the engine RPM is approximately proportional to the applied load. To operate correctly the SLC100 must be operating properly as well as having the GAIN, BOOST, RPM and STABILITY potentiometers set correctly. Sometimes a PITA to adjust correctly.
The prototype unit employs two circuits that convert the PMA frequency output which is proportional to the engine RPM as well as the inverters %Load output. The PMA's frequency is converted to a digital frequency using a opto-isolator. The opto-isolator's digital frequency output is fed to a Frequency to Voltage convertor who's output is sent to a 8 bit microcomputer to measure the engine RPM. More on the 8 bit RISC microcomputer later.
The invertors Load sensing output is also sent to the 8 bit microcomputer. It's a 0-5 VDC level representing 0-%100 load.
Based on the PMA "Frequency" input and the %Load input the microcomputer then adjusts the 831's actuator to achieve the appropriate engine RPM based on the load applied. Adjustment of the actuator position is achieved using a PWM (Pulse Width Modulated) output from the microcomputer to trigger a NPN darlington transistor to control the actuators position by varying the "voltage" to it.
The microcomputer constantly monitors the PMA frequency (engine RPM) and %load to constantly maintain the correct engine RPM.
The 8 bit RISC (Reduced Instruction Set Computer) microcomputer is a ATTINY85.
Here is a picture of the SLC100 and the prototype replacement. The 14 pin IC is the Frequency to Voltage convertor, the 8 pin IC is the 8 bit ATTINY85 RISC microcomputer, the 4 pin IC is the opto-isolator. Device headers contain the needed resistors and diodes to make the PMA Frequency sensor and %Load sensor circuits work. The TO-220 device is the darlington power transistor to control the 831A's actuator position. The big green resistor is part of the PMA opto-isolator Frequency conversion circuit. The two TO-92 devices are +5 and +12 VDC voltage regulators to power the various prototype circuits.
Close up of prototype. Not pretty, hey it's a prototype!
A picture of the prototype installed in one of my 831A's
Here is a video of one of the initial runs today of the prototype installed in one of my 831A's. The video is of the initialization, lifting the actuator target off the magnet (not shown), initial start, adjustment to no load RPM, application of 1.5 KW load with throttle up, application of 3 KW load with more throttle up to full load RPM, reduction of load to 1.5 KW with throttle down, reduction of load to 0 KW with return to idle RPM and then final shutdown. All controlled with the prototype governor controller.
https://www.youtube.com/watch?v=UeFscHrwO1c
After more testing my hope is to turn the design into a proper PWB design and possibly make units available for sale. Target is to potentially make the replacement available for much less than a new SLC100. PWB design underway already.
The big bonus is no need to tune the 4 potentiometers and eliminate the moisture issue. "Production" controllers would be 100% conformally coated.
Wish me luck!
I design and prototype circuit boards I also have a rapid prototype circuit mill that mills them up 6 inches square max size if you finalize schematic I can convert it to Gerber Files and run you a few circuit boards then if everything is ok you can take the Gerbers and email directly to a board house and make a bunch if you want , I'll do it for free cause I to have been fighting the darn 831!
Marty
kloppk
4,205
Massachusetts
Marty,
I appreciate the offer.
The schematic is finalized and I already generate the needed Gerber files to get them fab'd by a PWB fab house.
Have had great results with the house I use. Quick turn times, great quality and reasonable prices.
If I can help you with your 831 woes just let me know.
Good to know you have your own mill setup. Will keep it in mind. I'm working on a completely unrelated project that may require getting prototypes made. Won't be for a few months though.
Kurt
profo
75
jeanerette,la
Marty,
Kurt
Kurt no,problem I also have a 3D printer if you need small plastic parts also, For circuit board I run Eagle software, not to say anything wrong but if you update your boards later you may want to enlarge your flowthroughs and fill with solder I have to make boards for saltwater environments and that's where most problems arise even after conformal coated.
Marty
kloppk
4,205
Massachusetts
No need to subscribe. It's a real product now. They are available in the Classified's section of the forum.
CallMeColt
1,732
Wilson County, Texas
I have seen your ad but found this thread for the first time. Really good stuff!
I just got myself an MEP-831A & started going through it. I'm not sure if I will need a controller but all the linkage was messed with.
At your price, if I have any issues at all after getting the physical adjustments correct, I'm just going to order one of yours.
