JoeJrTheBarber
- 19
- 0
- Chicago, IL
Evening,
My new to me Humvee is a blast to drive but this cold ass Chicago winter is really taking the fun outta it as a freeze my balls off with the sad excuse of a heater these things come with. Even on full bore the thing does generate heat but the truck just doesn't retain it to make the truck fun to drive. Plus having the soft top, doors, and back rear curtain with a 2' gap isn't really helping retain the heat the heater does give off. a full "hard top" conversaion is in the works but who knows when that will all be sourced and installed..
So, my question: Have any of you dudes replaced and or added a Mojave style heater setup in your rigs ? The Mojave is from Flex-a-lite and is a pretty rad / compact setup that takes just two coolant lines and a 12volt source to get going and blows a said 14,000BTU of heat . An before someone posts it I am aware the trucks run on 24volts but I already have a 12volt breaker to wire stuff like this into. Not sure but I'm guessing the stock setup / heater doesn't come close to the 14,000 BTU claim of the Mojave but don't quote me on that as I am not 100% sure. I was thinking for ease of packaging and to not have to re-invent the wheel (so to speak) to add the Mojave under the left rear seat and use it along with the stock setup. The Mojave would have its own separate control for fan speed, which I could control and vary depending on if I had rear passengers or not (usually don't).
Anyone done something like this ? Thoughts ?
![555.jpg 555.jpg](https://www.steelsoldiers.com/data/attachments/491/491022-405fa6449a583d8d7bfb9e43bc9ec890.jpg)
![5.jpg 5.jpg](https://www.steelsoldiers.com/data/attachments/491/491023-6306dc9f378f009cb96ef58bba245fa0.jpg)
![55.jpg 55.jpg](https://www.steelsoldiers.com/data/attachments/491/491024-e684fa3f1d7e3005cdd6e506dffa68e8.jpg)
