There was questions on here for suggestions and yet hardly anyone has helped! People just saying we are trying to make a quick buck and that the truck is not fully fuctional. I’m not trying to fight with people but I don’t appreciate people automatically talking **** on people! We have legitimately been doing everything we can to get this issue fixed so the guy can have a good working truck. He knows that.
Yeah! It took 4 hours to come up with the responses below? Unacceptable. I'd ask for a refund (to this free site full of information and a search feature?) I'd be almost as mad as the guy who went to buy a running and driving truck just to find out it has current (and past) transmission problems.
"Did you try shifting through gears manually?"
"I can't think of a way for CTIS to interfere with the transmission.
Presume you have a transmission problem. I'd have thought maybe the fluid was cold, but you said you got it warm so that rules that out.
The wreckers are heavy, and go through transmissions faster than the cargo variants."
"Put transfer case in low range and see if it will shift thru the gears. If it does then you have a pressure problem. So its internal transmission.
Check the modulator cable to ensure it is not broken or the spring came apart."
"Spring is inside the modulator base on the transmission...you simply replace the whole unit."
"Kinda basic, but make sure the PTO is not engaged. When I picked up my wrecker at the base, the PTO was engaged and I couldn't go faster than 15mph. Took a few minutes of checking everything to find it and take it out of PTO, then it would drive normally."
"Take note, the front winch pto and the crane pto are separate controls. The crane pto lever is on the floor, left side of the drivers seat. Sounds like the crane pto is engaged. Reference the operators hand book (-10).
It is a tricky sequence of control manipulation."
