Idle Vibration Normal?
rodent
10
Denver, CO
Still new to this M1008 truck and I'm trying to find out how much vibration is normal in these trucks at idle. The dash rattles and other parts rattle on the inside with the truck in drive at a stop. Also the bed rattles and you can clearly hear it outside the truck.
Is this a common symptom of a bad harmonic balancer or could it be something else something else? I may check the flexplate too and motor mounts too.
porkysplace
1,496
mid- michigan
The harmonic balancers are know to be a problem on these , 30 year old rubber binding them together.
rodent
10
Denver, CO
That was my thought too. I know they tend to go out and could cause damage to the engine.
Thoughts on a decent brand to get? Or are they are all the same? I know Fluidampr is the best but $400 is a little much to spend. I'll try that first since its easy to swap out.
rodent
10
Denver, CO
Thanks! Just wasn't sure if vibration was a symptom of a bad one or not. Either way it needs to be replaced from age.
TGP (IL)
36
Metro East IL
Check your motor mounts especially the right side.
I'm sure you'll find there shot and the engine brackets are touching the cross member.
That sets up all kinds of noises and vibrations.
Tom
ken
27
Houston Texas
If the rubber on your balancer has ANY CRACKS then replace it!!! Don't take a chance. I have broken a crankshaft this way.
rodent
10
Denver, CO
Tom
Thanks Tom. Will look there as well. Hopefully they are not too hard to get to. I do have an engine hoist that can lift up the engine a couple inches.
Ordering one tonight regardless. Thanks!
Barrman
2,223
Giddings, Texas
If all the parts mentioned above check out ok. It could just be as simple as your idle speed. My first M1009 had a terrible harmonic that made everything shake and buzz after I had driven at highway speeds for more than 20 miles. I figured out a way to check idle speed and just a 50 rpm difference made it all better.
ken
27
Houston Texas
You will not need to lift the engine to replace the balancer. Just remove the fan, shroud and pulley. it comes off easy with a good puler
cucvrus
10,505
Jonestown Pennsylvania
Motor mount on left side will allow the stud of the exhaust manifold at the oil dipstick to chew into the upper frame flange. May I suggest Energy Suspension motor mounts? And the right side of the right will sink and rest on the fuel feed line. Causing a possible minor fuel leak and allow the system to drop fuel and make for hard starting. Just a thought. I changed my motor mounts and put new ones from NAPA in place. 1 trip to Rausch Creek and the mounts were sunk. I think they were old stock and the rubber disintegrated on a hard pull at the power lines. Good Luck. Stay warm. Do 1 side at a time and a piece of wood and bottle jack work fine.
159
Houston/TX
I replaced my motor mounts with ORD competition motor mounts, and also replaced harmonic balancer, transmission cross-member and adapter between transmission and transfer case......truck still has all kinds of rattles and buzzes/vibrations......what I have noticed though is that depending on what kind of terrain I've put the truck through in 4WD, the severity of the rattles/buzzes/vibrations may change and/or migrate to different areas of the truck......bottom line my '84 M1028 is a beast offroad, and I chalk up rattles/buzzes/vibrations to 30+ year old suspension/frame technology.......doesn't bother me.
cucvrus
10,505
I am surprised you still have teeth in your head. They are solid steel on steel motor mounts from looking at the picture. Why are you afraid all 135 HP in the CUCV are going to flop the engine over if you accelerate too fast? That truck has enough rattles it don't need solid motor mounts. Now I would be afraid of breaking things. You want the flex with at least urethane mounts. Have a great day. Vibration free I hope.
http://www.offroaddesign.com/catalog/motormounts.htm
Ilikemtb999
46
Denver, CO
They have urethane bushings in the mounts. They’re in the pictures in the link you posted.
rodent
10
Denver, CO
They do transmit more vibration than the factory mount. I'd rather use the stock rubber clam shell engine mounts or even do the energy bushings inside the clam shells. Held fine on a modified 496 BBC.
Barrman
2,223
Giddings, Texas
Do the timing cover front seal while you are at it. Also, get the balancer puller kit with the 16x 1.5mm thread main shaft. Then you can use it as a balancer installer too.
rodent
10
Denver, CO
Thanks! Yeah I was just looking for a bolt that size to install it with my HB tools. Also need to verify pulley is good. Hopefully Dorman HB is ok to use. Ordered the seal 2 days ago, need to go get it.
Still have a vibration in drive at a stop. Need to look at trans mounts too.
