coachgeo
- 3,394
- North of Cincy OH
from what Scottmandu reported seems middle is best, but only marginally.
Seems to me... and am no engineer.... Based on that there is a differential that sends torque to both axles... but mostly to the one that has some slip... any axle in the 6x6 pair with Detroit in it will get sent potentially less torque overall in general cause the Detroit axle will be the one NOT to slip as often . When in mode the torque is split equal to both axles and locker now is in maximum affect. Not sure in mode if one axle is better than the other when deciding where best to have it installed.
So with that in mind and being that no matter what axle it is in... a Detroit is always active along with it's differential. It will begin to lock the slipping side at some point in a turn (thus some scrubbing of tire on cement). The furthest back axle will have a higher radius in the turn compared to middle axle in front of it. Thus it will scrub more due to this. For tire wear this says middle axle is better. (if understanding all this correct.) If you don't care about tire wear... sounds like it makes no difference?
Anyone else see it that way? If any of you have a clearer or different understanding please to speak up. Figure its bound to be helpful to others who want to get their head wrapped around the understanding of how the rear pair of axles in a 6x6 work.
