Reworked LMTV
Expedition Campers Limited, LLC
- 1,535
- 1,202
- 113
- TN
I think the some of the confusion stems in part from the use of the terms "locked" and "locker". Maybe someone could draw a simple stick diagram to help ?
you might be right... though feel it may be more than that. The lock of the power divider.... that locks the two axles together..... IS essentially a locker.... works basically like an ARB... but it locks a differential that sits between two axles instead of a differential between two wheels. Any differential could have a locker and it will lock together whatever is on each end.I think the some of the confusion stems in part from the use of the terms "locked" and "locker". Maybe someone could draw a simple stick diagram to help ?
Ah, ok so I think I do understand your explanation. So is the tire that has the least traction detected and the power flows to the grippiest tire assuming it is in MODE, or is this not the case, and power flows to the tire with no traction, and thus the reason people want the Detroit style locker, to lock both tires on one axle?you might be right... though feel it may be more than that. The lock of the power divider.... that locks the two axles together..... IS essentially a locker.... works basically like an ARB... but it locks a differential that sits between two axles instead of a differential between two wheels. Any differential could have a locker and it will lock together whatever is on each end.
So once one understands a Power Divider is essentially a differential. It is one that acts in the same manner as a differential inside ONE axle but instead sits between two axles. Think of Power Divider like a Pumpkin sitting between axles. Makes more since when one realizes any automotive "differential" distributes what gets torque based on how much one "thing" revolves compared to another "thing". Does not matter if those "things" are two different axles; such as the one in the Power Divider.... or the Left / Right wheel, inside a single axle. AKA It "differentiates" what is happening to one thing compared to another, and applies torque accordingly.
With that understanding then one can see what a locker would lock together, based on where it is located..... If it is inside a Power Divider.... it will Lock two axles together.... If it is inside a single axle..... it will lock Left and Right wheel together.
or did I just make it more confusing lol
... OK if I understand all this right.....Ah, ok so I think I do understand your explanation. So is the tire that has the least traction detected and the power flows to the grippiest tire assuming it is in MODE, or is this not the case, and power flows to the tire with no traction, and thus the reason people want the Detroit style locker, to lock both tires on one axle?
The power divider completely disconnects the rear most axle ...
I can tell you definitively that the 6x6 rear axle has no power to it unless the transmission is shifted into MODE.
Well there we go, it’s a plain old typical power divider after all...
These statements are incorrect BTW. Spin the input on the power divider (as I just did) with it unlocked and hold the rear output and the middle spins. Do the same with the middle locked and the rear output spins. With the divider unlocked torque is varied between the two axles. By locking the power divider the differential in the unit is defeated. This is also how the manufacturer states operation is.
Sometimes you have to push away from the computer and physically check. Thanks for clearing everything up!
I've been thinking about this for a while for my own M1083 in the future. My thinking is, probably the only reason we are interested in lockers are for the off road traction. On road we will have some increased tire wear no matter the positions so........the center axle would probably be the best to install it on. Especially if you are planning on traveling on very uneven ground. If you have ever seen any videos of three axle trucks off road, it is amazing how often the back axle is hanging in the air doing nothing at all on ROUGH terrain. I believe the locker would spend more time being useful if it were on the middle axle.from what Scottmandu reported seems middle is best, but only marginally.
Seems to me... and am no engineer.... Based on that there is a differential that sends torque to both axles... but mostly to the one that has some slip... any axle in the 6x6 pair with Detroit in it will get sent potentially less torque overall in general cause the Detroit axle will be the one NOT to slip as often . When in mode the torque is split equal to both axles and locker now is in maximum affect. Not sure in mode if one axle is better than the other when deciding where best to have it installed.
So with that in mind and being that no matter what axle it is in... a Detroit is always active along with it's differential. It will begin to lock the slipping side at some point in a turn (thus some scrubbing of tire on cement). The furthest back axle will have a higher radius in the turn compared to middle axle in front of it. Thus it will scrub more due to this. For tire wear this says middle axle is better. (if understanding all this correct.) If you don't care about tire wear... sounds like it makes no difference?
Anyone else see it that way? If any of you have a clearer or different understanding please to speak up. Figure its bound to be helpful to others who want to get their head wrapped around the understanding of how the rear pair of axles in a 6x6 work.
Except when the locker gives you a (rare) bit of differential action such as when there is a good amount of weight on the axle and you are "freewheeling", it is always locked. It will lock "tighter" if you put any sort of torque on that axle. Such as when you are applying throttle or engine braking. And when it does give you some differential action, it makes a pretty good BANG. But before it skips a tooth and bangs, the locker makes the whole driveline wind up. The lighter the vehicle/load, the more noticeable it seems to be. And that can make for some scary handling. One locker can be bad enough at times. That's why I'd like to know how much more TWO lockers would affect these trucks on pavement. I'd like as much traction as possible off road but not at the expense of being constantly paranoid, waiting for my truck to scare the poop outa me.Should I assume that any axle that has a non-actuated locker is locked up all the time? If this is the case, would not scrubbing occur with that axle is engaged or not? Maybe I am wrong.
