- 6,853
- 672
- Stratford/Connecticut
Just unplug the controller for now
Keep it here.... we are all selfishly learning along with you...New to site, so not sure if we should have this conversation off of this thread????
QRVs are pretty bullet proof. Run Flat light is looking for large tire pressure imbalance >30 to 50% but a upper air line leak can fool the system into thinking it has the imbalance.Stellaevil, thanks. I never could find any discussions or information about HWY and RUNFLAT flashing at the same time. I assume a faulty QRV could cause this?
www.steelsoldiers.com/showthread.php?175911-Central-Tire-Inflation-System-(CTIS)-AXTS-0015-2018There is a CTIS controller manual posted around here, and I think it has all the flashing error codes in it.
A0 or A1?Thread hijack - CTIS issue... My M1081 ....
A0 or A1?
If the system comes and flashes Highway one time and then 5 lights without checking the tire pressures it doesn't like the atmospheric reading from the pressure sensor on the PCU. Connector pins, wiring, the +5 volts from the ECU. There is a link to the manual a couple of posts back.
If the system comes up flashing the highway light and then the PCU cycles once and the 5 lights start flashing...the system did not get a good tire pressure reading it was below 5psi. Large air leaks in lines or the inner axle air seals. The pressure check only lasts 2-3 seconds so you can only check for air leaks during the check.
There used to be rebuild kits for the m939a2 ctis valve body. I think it had new poppets and o rings. Maybe something available for the lmtv.
For what it’s worth, my ctis has been a central tire deflation system for a long time. I finally got around to working on it and found when it would go into a deflate cycle it wouldn’t stop until the truck was off and tanks drained, also had 5 flashing lights. I took the pcu apart, cleaned it all up and re installed to only find the same issue. Under a hunch I went and took the vent line off the pcu, and bug guts flew out as the line depressureized. Pressure in a vent line, clogged due to bugs. With the vent line off, ctis works great! For now that is.
