cheepsk8
- 0
- 6
- N.E. Wyoming
So I've been thinking about getting a genny for backup purposes. My house is all electric. The furnace, water heater, range, everything. how do I size a generator for my needs?
813 is 400Hz. Do not get this unless you have a special purpose. In the civilian world the only thing this can be used for is resistive loads only. Can not be hooked up to any inductive load.I see the mep813 is spec'ed out at 400hz, should this be 60hz.
What am I missing
Howdy,I see the mep813 is spec'ed out at 400hz, should this be 60hz.
What am I missing
It would be probably be cheaper to go with an MEP-803a from the start and build a load bank as a ballast load that could be added or subtracted to the total load giving him the capability of having the higher KWs at hand if needed.Assuming you don't have electric heat or a heat pump, the water heater could be the biggest constant load at 4500-5500 watts. This could be enough to put you into a MEP-803A.
However, buying a load manager using CTs and relays could easily help you size down since that water heater isn't always on.
My furnace is electric. As in electric heating element.You have electric heat or the furnace needs electric/gas/oil? Thats the big variable i see here. I can run my electric dryer with my 802 but use a wood stove for heat. I have an electric stove and the 802 can also run that. If you have a gas/oil furnace and dont mind not running everything at once then the 802 should do what you need.
Ouch, how many kW? If it's anything like electric heat strips used with heat pumps, there's a lot of variety.My furnace is electric. As in electric heating element.
The mep803 will most likely be to small for your needs.My furnace is electric. As in electric heating element.
I would go with an MEP-003A. Lower purchase cost, simpler to operate and repair and extremely reliable. The 803A is a nice unit but since Puerto Rico they're selling for "stupid money". For either one of these, you would likely have to do some load management so you couldn't just run everything in the house as if you were on the grid. You'd have to determine your full load amps needs as others have mentioned.So I've been thinking about getting a genny for backup purposes. My house is all electric. The furnace, water heater, range, everything. how do I size a generator for my needs?
Agree--I love the sound of a D198 or D298 running at load. They just purr even at full load or overloaded a little. I only have Libby or JR Hollingsworth in MEP-004A or 005A models--either way they're both champs!Fermont design, White engine, the 004A and 005A just are hard to beat for bigger loads.
You are right. I meant Hollingsworth.Agree--I love the sound of a D198 or D298 running at load. They just purr even at full load or overloaded a little. I only have Libby or JR Hollingsworth in MEP-004A or 005A models--either way they're both champs!
Don't think I have any Fermonts except in the 80X series.
