Need 803 parts, crankshaft bolt.
CapePrep
197
MA
Anyone know where I can get an 803 crankshaft bolt. The one that goes in the water pump end of engine. I have reached out to someone that had parts listed in classifieds but no answer. Any help would be greatly appreciated. Thanks
Zed254
468
S. Hampton Roads, VA
In TM 9-2815-253-24P (Page 48 and 49 of 101) the Crankshaft Bolt is FSCM 44940 Part Number 188-6196. Still looking for NSN.....
I get some sort of gyroscope with that part number: http://www.parttarget.com/6615-01-033-4774_6615010334774_1886196-2.html/-B11E01E8-5A1B-4884-AA86-51026B5E0B74
Manual may have typo on part number. 186-6196 showed some Onan hits. A search on that part number gets a possible NSN of 5305-01-361-6562. Note info on this parttarget search of 186-6196 http://www.parttarget.com/5305-01-361-6562_5305013616562_186-6196.html/-b11e01e8-5a1b-4884-aa86-51026b5e0b74?searchtext=186-6196&searchoption=sku&originalsearchtext=186-6196
MEP-802A ARMY TM 9-2815-252-24P shows part number 186-6196, NSN 5305-01-361-6562. NSNs match.
jamawieb
578
Ripley/TN
Try Delks Army Navy. 1-336-629-0991. Ask to speak to William. Try to figure out if you need anything else so you can save on shipping.
Zed254
468
On the 802a I'm showing part number 186-6198.
I got that 186-6198 and part count called for 4. I searched on the 186-6196 and it showed figure 13 and the diagram part number 5: I think this is the crankshaft bolt.
Green Mountain has an "MEP802A-MEP803A BOLT Onan 186-6196" but no usable description. They do have a Lister Petter part number of 751-14250.
Good luck.....
Looks like a right hand thread and NSN does not match, though: https://www.thexmod.com/item_detail.asp?id=1732
CapePrep
197
MA
Thanks for the help Gentleman! I will post back as to what I find. Going to get this 803 on Saturday, so will be tearing into it on Sunday!
Farmitall
280
Eubank, KY
Guyfang
27,230
Burgkunstadt, Germany
Good luck.....
Parts count, is I think you mean how many in the set? In that case, its 1, (one) each.
The green mt. part is the correct one.
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
The part, MEP-802/803 is;
CUMMINS POWER GENERATION INC. Cage 44940
NSN 5305-01-361-6562, SCREW,CAP,HEXAGON HEAD
Onan 186-6196
Cummins 186-6196
Farmitall
280
Eubank, KY
What are the dimensions of this specific bolt? Unless its some weird dimensions/thread I would think it should be available at most any place that carries left hand thread bolts at a fraction of the obscene prices being asked in some places.
porkysplace
1,496
mid- michigan
Run the NSN/PART NUMBER through www.parttarget.com it should give you the specs. If you get it at a off the shelf bolt house you need to get the correct hardness bolt.
