Expendable
- 1
- 6
- SoCal
Congrats on the Humvee! I would love one to match my Hummer.
I stay indoors during storms.Will this be seeing storm hunting duties in the future? I like it!
Well I drove it around a little more last night on the "back 40" so to speak. (There's 1400 acres behind my place of forestry land) Temp steadily increased. So last night I pulled off the crossover manifold and t-stat. They were nasty! Lots of brown icky in it as well. I replaced the crossover with a spare unit I have, due to the corrosion internally. I've reinstalled everything without a t-stat and am in the process of flushing everything. The original t-stat opened, but had scale all over it. Also reading up I found that the return tank lines were plugged up at the tank. I poked the crud clear of it, but noticed the holes are very small. I went ahead and opened up the ports with my drill as retiredwarhorses recommended in the thread. Hopefully I'll have it cleared out in the next half hour or so.
I'm in the same boat. Replaced the sender stat, and gauge. Still hot (235-240), no boil-over even with the cap off and straight water. I'm stumped.So it seems to be improved a bit, but still warm. It crept up to 235-240 on the gauge. The fan did kick in before. But when I got home I threw the IR therm on the crossover tube and only saw 218F. The upper radiator was around 210. The lower portion of the radiator showed 183. The truck seems to run fine, no steam or anything. I'm wondering if I have a bad gauge. (Sender was replaced)
