Source for wiper motor with pump
mcne2026
Kuna, ID
Howdy folks. Bought my first CUCV, a M1009, about 12 years ago. Always regretted selling it so I just picked up a M1008 this week. Taking some time to go through it and putting together a list of everything it needs. First on my list is the wiper motor. It is really slow and has almost no strength in low and hardly moves at all on high. I remember having the same issue on my M1009.
I'm looking for a source that sells the wiper motor with the pump built in, like stock. Everything I am finding does not have the pump. Appreciate the advice.
rodent
10
Denver, CO
I got one from advance auto and used a 30% off coupon. Be sure to get the 84 pump. I tried to get an 1986 pump for my 86 and it was the wrong one.
mcne2026
Kuna, ID
Thanks guys. I got one for an '84 from Rock Auto. Decided to go with the AC Delco despite the higher price. I needed seatbelts as well and was shocked at how expensive they are. $90 per seatbelt was a lot higher than I thought they would be.
rodent
10
Denver, CO
I'm looking at replacing my belts too for a color change since I'm going all black. My current belts work fine but are a little faded. I found a new set on ebay for $150 for both sides but the only thing is the retractor base on ALL aftermarket seat belts do not match the OEM GM.
MarcusOReallyus
820
Virginia
That's because your "86" is not an 86.
It is an 84, regardless of when it was manufactured. The Army didn't want to mess with changing parts, so they required GM to make them all with 84 parts; no changes with model years.
So, yours is an 84 that happened to be manufactured in 86.
rodent
10
Denver, CO
I know that now but did not realize that when I first got the truck and the pump had to be replaced ASAP. All the parts are made to be interchangeable regardless of year.
doghead
4 Star General /Moderator
1,193
No ebay links.
Tinstar
2,613
East of Edmond, Oklahoma
I think it’s a little more in depth than just the column switch.
Search the forums as it’s been covered in detail before on what exactly you need to do.
rodent
10
Denver, CO
You have to add the pulse module and order both turn signal stalk and switch. its not cheap but doable. I got a pulse board from a tilt column I may install.
