MC-7 Oil Separator Filter PN
kassim503
Stony Brook, NY
I have recently purchased a MC-7 Davey compressor, and from what I read its Davey Model 14M125. The tags have been removed as the previous owner "De-Militarized" it, but it has a john deere 3 Cyl diesel and a rotary vane Davey Compressor on the back. I went to change the hydraulic oil in the air end with a fresh fluid and filter, and may have overfilled the unit. My motivation was that the military models have a decal on the oil tank that says "Fill to Overflowing," and I did as such. Unfortunately the air outlet blows a mix of hydraulic oil and air at the same time now, which is usually an indication of the in tank air/oil separator filter failure. Does anybody know a PN for this filter?
Also I filled it with cheapo AW46 Oil as per the cross reference from the MIL- number spec'd in the TM for a 6M125. Help!
niall0890
northern ireland
Hi there new to the fourm i have just bought the same compressor it is blowing the safety valve when it gets up to pressure ...it is also blowing oil out through the air outlets ... do you have a manual for this model also do you know where i can find separator filter i live in ireland so it is very hard to find over here many thanks
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
Coal Cracker
Weatherly, Pa.
I just bought an MC7 as well , are there any parts or TM manuals available on these ?
I need an air filter canister lid and air filter part numbers . I also need the hosing connecting the intake on the engine and the vane manifold to the filter canister . Thanks
