AIE1
- 3
- 8
- Arlington, Virginia
So the NorthEaster comes through and I fire up the MEP-003 that has done very well through storms since 2012. Just broke 700 + hours. She was working fine set her to 60hz she takes load fine for a day then all of a sudden I start to see either Hz pegget to the high side after readjusting back to 60 a short time later all the way to the left. It appeared with house loads like furnace (oil burner), well pump, 3 fridge’s and hot water heater didn’t seem to effect the load at all before. Now I’m at a loss, I did the steps in Table 3-3 Troubleshooting #8 I did fine one of the AC output connection slightly loose, however before I could continue to trouble shoot regular power came back on. I will admit I’m no generator man, so I sure could use some good advice.
Thanks in Advance!!
Thanks in Advance!!
