two.fiveM35
- 11
- 38
- Victoria , Texas
Mushroom soil? Please elaborate...View attachment 719782Picked up 2yards of mushroom soil to work into the yard
Just going to use 1 cylinder a 4" bore . I am going to add a 6" x 6" I beam to the center of the trailer and run a full span cross bar and stagger weld some angle iron between what I have on my existing ramps so that the whole back of the trailer will be one big ramp. That will be its own unit. I may run some hoses back there and feed off the front tank. I got 400ft of 3/8" double wire 3000psi hose for $150 last week so distance isn't an issue.Wes, The lights look good, nice and bright. Looks like you put in a nice size tank...that should do it. Were you using one or 2 cylinders on the rear? Are you entirely re-making it or filling in between? Your a busy man!
Have you ever got the NY delivery worked out? The man bringing the M322 back from Grendel has had something come up. I need your help, if your available. Thanks
Before black out.Wes, The lights look good, nice and bright. Looks like you put in a nice size tank...that should do it. Were you using one or 2 cylinders on the rear? Are you entirely re-making it or filling in between? Your a busy man!
I agree. It's not my video. Just shows how it's made. Nice thing is that even if the water freezes it still catches them. Then I just have to transplant them or give to the cat for a "real" toy.the water needs to be deep enough to drown them!
