Russ Knight
- 1,059
- Perry, FL
Doghead has often admonished folks having air issues to service their air dryer. He's right. Service your air dryer!!! I don't think mine had EVER been serviced.
View attachment 722406View attachment 722407View attachment 722408
The haldex purest air is the normal upgrade folks go to.What is the best air dryer replacement for a 923A2?
Did you get a 24 volt version? Or can the dryers handle both? Every where Ive looked says it can handle both 12v and 24v but not option when ordering?Wow, FinditParts moves fast, unit here already! If you can't find a new MRAP Pur-est, this is the way to go.
Your heater off the PureAir version that came on the 5 ton trucks will transfer over to a Purest dryer. The heater just snugs under the dust cover. They are interchangeable.Did you get a 24 volt version? Or can the dryers handle both? Every where Ive looked says it can handle both 12v and 24v but not option when ordering?
Its. Wabco one. Thers is a thread on it. You have to drill out a port on the dryer for the control line from the firewall governer. Block one port off on the front and install the Air in and air out fittings. Works fine. Its 30lbs lighter than the stock air dryer.Simp5782. You were "testing" an air dryer from another member. Can not remember who but I had contacted him and he said you were the guinea pig and to wait until your review?? Maybe Fuzzy?
Link to that thread?Its. Wabco one. Thers is a thread on it. You have to drill out a port on the dryer for the control line from the firewall governer. Block one port off on the front and install the Air in and air out fittings. Works fine. Its 30lbs lighter than the stock air dryer.
Sent from my SM-G935P using Tapatalk
https://r.tapatalk.com/shareLink?ur...share_tid=175982&share_fid=20191&share_type=tLink to that thread?
I'm stuck on stupid phone and can't maneuver worth a crap.
I need a dryer.
