- 463
- 262
- 63
- Seville, OH
1998 M1079. What is the voltage and current draw across the red start button contacts? Thanks!
I'm looking at a 2A 12v tubular switch.Low current. I believe it’s 24 volt. You can replace with most simple keyed momentary switches for security purposes.
What is the coil draw of the starter solenoid?I think that's abit small 12volts 2 amps would only be 1 amp 24 volts it only does starter solenoid but it a big one. I would say at least a 10amp rated at 24 volts at min ever time you push it it arcs inside and if it's to small will quickly wear out
Big Tom
