cucvrus
- 10,502
- Jonestown Pennsylvania
Why would you want it in 4wd? Sure not using 4WD to save fuel.The only thing I don't like about the gear vendors unit is it only works in 2wd.
I have the Goodyear MTR Kevlar 31X10.5x15 on a few of my M1009's. I cut a few side walls in the past on rocks during logging and off roading. Never cut an MTR yet. They have some nice scars from being pinched. I think the heavy side walls are the trick. The Goodyear Duratraks have the same HD side wall. I like when the side wall bead protrudes past the rim edge. It adds great protection and has helped the bead from being compromised during air down in mud. I had the BFG Baja claw. Not a huge fan. They were cheap and new so I ran them. better results from the Goodyear's in my experience. Others may vary. Fair enough. Cheap tires are just that nothing more.Rolling over something is completely different that hitting something with a sidewall.
I have had the BFGs A/T and was a great tire.
Been running Michelin’s now for years.
Never an issue
Hit a piece of steel on sidewall (driving slower than walking pace) that I could have rolled over easily without trouble.
Sliced it open and ruined tire.
Small piece of angle iron that was hidden in grass.
Had ran over it many times and didn’t know it.
Tires just aren’t built, for obvious reasons, to handle extreme trauma on the sidewall.
I know the specialty off-road tires for rock climbing are much better, but still not as strong as the steel and poly belts for the regular part of tire.
I think a lot of guys want to be able to do highways speeds (45+ mph) in 4wd, but in my opinion, if you need 4wd to maintain control at that speed, your just going to fast for the conditions anyways.Why would you want it in 4wd? Sure not using 4WD to save fuel.
Make sure to use a torque wrench to install the unit to the extension housing as per the instructions. The studs are a fine thread into cast aluminum and easily stripped out. Also..(unless they updated the instructions) they will call for a discontinued GM gear oil. The new oil you'll need is 1-1/2 bottles of Lucas 75-90 synthetic. And it will need to be changed every 3000 miles. And lastly I was never able to get the 4WD shut off to work correctly (blue wire) so I've always left it unplugged. You'll have to manually turn off the GV before going into 4WD...Thanks! Im pretty sure theres no real fabrication. Only the driveshaft shortened. Looks like theres a lot of room underneath. Some people have had to bang out some sheet metal but I dont think so on this. The rest is all bolt up and wire. Pretty impressive packaging and instructions and everything so far. Theyre not heavy on communication compared to what Im used to. But very solid when it comes down to it. Reminds me of old school mail order days. Be patient and its Christmas via U.P.S.![]()
Dude.Going over the Pre-flight checklist for tomorrow.View attachment 722938View attachment 722939
Yep that is true. With the tire market so competitive today, when you see a tire going for much more then the others that usually means they added something above normal to it. Like extra ply's.You absolutely get what you pay for in tires.
I will have a look at the Goodyear’s you mentioned.
Michelin doesn’t make the tire I want in the size I want so I’m shopping now.
Yeah cool article. The point of an over drive for me wasn't really so much for fuel economy, but just to be able to reliably go 70-80 MPH on the highway while pulling a trailer. Gear vendors must have revamped their instructions sense I bought mine. I had to call their tech line to find out about the gear oil and that's who also told me about the 3000 mile change intervals. I've though about somehow rigging up a filter system, perhaps something using an electric fuel pump plumbed into one of these Frantz filters?http://www.frantzfilters.com/product/universal-kit/I just looked at the website. They are saying 5,000 miles. Did a little research on the lube requirements, and found this interesting article. Thought you might want to look at it.
3,000 or 5,000, that's still crazy. The cost of the lube wipes out any fuel savings, and probably more.
Th400 + 3.08 gears + 31x10.5R15 and not fixing what ain't broke means I have the scratch to buy a motorcycle for the warm weather.Th400 +gear vendors +4.56 gears + 33" tires @ 80 mph = 2900 rpms 700r4 in same setup would be at 2600 rpm's at 80.
400 = truck transTh400 +gear vendors +4.56 gears + 33" tires @ 80 mph = 2900 rpms 700r4 in same setup would be at 2600 rpm's at 80.
The civy blazers came with the 700r4 stock.400 = truck trans
700r4 = car trans
