cucvegas
- 14
- 8
- NW Arkansas
I have tried three different keyed ignitions on the HMMWV, and none of them have worked correctly.
The first one I got from Federal military parts. I used a multi-meter and made sure the wires from the vehicle were labeled correctly (Battery, Ground, and Ignition).
I wired them to the new keyed ignition, and when you turn the key to "on", the wait light comes on and cycles the glow plugs as expected. However, when you turn the key to start the vehicle, all the gauges lose power.
I talked to Steve at Federal Military parts, and he had no idea why it wouldn't work, so he sent me a new switch in case that was the problem. It was not. The new switch did the exact same thing.
I then bought a 3rd identical ignition switch from the_amazon for $10 and made the wires with male bullet connectors. This did the same thing as the other two.
Any suggestions?
The switch has power (24V) between battery and ground when in "off" position. In "on" position it has 24V between ground and ignition. When turn the key to "start" in the spring-loaded position, it goes to 0V between ground and ignition. The "accessory" terminal on the switch is not used.
When I plug the original ignition switch back in, it all works fine.
Thank you!
Any suggestions?
Thank you!
