wandering neurons
- 112
- 43
- Fallon, NV
PM me. I've got my old parts
The variable pressure sender.Tank switch or pressure sender on pneumatic valve?
that's correct, But it also has a shut off. If there is no pressure it won't even switch any resistance.I believe its a resistance based sender. Higher pressure equates to more resistance. I could have it backwards though.
Therefore, unless system pressure is building it won't even turn the CTIS on. Once the ECU senses a change it monitors the values. or throws an error code.
I have a 2006 M1089A1, they only come with one style of airdryer in those years . The finned type was a thing of the 90's, if I'm not mistaken.Which dryer do you have? Is it the tube with fins or the purest style? The purest ones you replace the cartridge it’s under a black metal cover on top held with 4 bolts. If it’s the tube with fins replace the whole thing with a purest style one.
The Newer driers appear to be a change made when the C7 was used, so late 2004 and newer.I have a 2006 M1089A1, they only come with one style of airdryer in those years . The finned type was a thing of the 90's, if I'm not mistaken.
i was asking about
a) how to drain it ( think by using a 5/16 square drive)
b) how to make sure it's not clogged
then I can still decide whether I need to replace. But first I need to know if I even have to.
I have a gazillion things I need to go through, still. And If the air dryer filter doesn't need to be one of the things I have to spend money on right now, I'd prefer not to.I would just change it. Only around 75 bucks online. Comes with the o ring also.
guess all you can do at this point is just pull the dryer/filter out and see what it looks like? Lot of water certainly seems to say something is amiss there. I don't get any but mine still freezes when real cold..... grrrr....Does anyone know How to check if the air dryer is clogged? I get a bunch of water coming through the tanks when I drain them.
