jwhit612
- 0
- 0
- Taylors SC
Ok, this will probably be an easy solve for you guys, but I'm new to the whole military trailer thing. I just bought an M1101, manufactured in 1997, and of course, one of the first things I do is get on Amazon and buy some 12v LED replacement lights for the trailer. I looked up the numbers and it looked like I could replace all the bulbs all the way around with one LED bulb. I then connected a 4-pin wiring harness to the existing wireing (someone had unplugged everything under the trailer before I bought it so I just connected everything together right at the terminals). When I plugged it in, some of the lights worked and some didn't. Most of the running lights on the driver's side worked but the blinker/break light didn't, and nothing on the right side worked. After closer examination, some of the bulbs were blindingly bright but some of them were just barely glowing. You couldn't even tell it was glowing unless you were looking right at the diodes. It's not a bulb issue because I can swap bulbs one that's bright and one that's not and they'll reverse, so it's definitely a wiring thing. The first thing I thought of was a grounding issue but that shouldn't affect some lights and not others should it? What am I doing wrong?
