impi
- 7
- 8
- Loxahatchee, FL
I have read through the TM and Operator manuals for the 803 and could not find a clear answer on the operation of the auxiliary fuel supply function. I was fortunate to have received the supply line with my unit when I bought it at auction and I purchased the jerry can adapter to go with it. I have a two 55 gal lined drums which I use for reserve capacity for when hurricane season gets busy (fuel supply always seem to be an issue).
I did a test run over the past two days and ran the unit for around 25 hours. I noticed the fuel level on the gauge dropped from near full to around 1/4 tank and then bounced up again to about 1/2 tank and down to 1/4 tank and back up to 1/2 tank. I understand that the auxiliary feed pumps fuel into the day tank. What I'm unclear about is whether or not the aux function would fill up the day tank or does it just add to around 1/2 tank before it stops - I understand that the aux function is triggered by a float switch, and not the fuel level float.
Any feedback will be greatly appreciated.
I'm testing the setup and would like to get all the quirks sorted before hurricane season shows up - don't want any surprises when I need the equipment to function.
Regards
Regards
