WhoMe08721
- 124
- 43
- Bayville/NJ
Het guys,
So I finally decided to replace my leaking outer axle seals. But I have been pushing it off because when I replace them I all ways want to install (3) ARB Air Locker in too. Finally have time after the next (3) weeks to install them. My only questions about them are
1)I was not going use the solenoid and instead use (3) more air actuated transfer case lever mountain side by side under the dash. I would rather not have anything electric that can fail when off-roading.
2)I was going to tie them in to the on board air system. Would the air compressor and stock tank have enough air to run (Air over hydraulic brakes, transfer case for the front axles, and all (3) Air Locker) Or would I need to install more air storage tanks in the truck.
3)Also should the two rear axles be on there own air lever (Switch) or should they be tie together? What are the cons and pros of both ideas?
4)Final is there any go literature, books, video on installing them besides these one (https://www.steelsoldiers.com/showthread.php?87548-ARB-Air-Locker-RD145-Install-Thread-Pics-and-Tips , https://www.steelsoldiers.com/showthread.php?104894-ARB-install-in-the-rear-axle, http://www.powerblocktv.com/episodes/XT2011-01/diesel-buggy-part-four-suspension-steering, https://static.summitracing.com/global/images/instructions/ARB-RD145_i.pdf)
