coachgeo
- 3,546
- North of Cincy OH
if you have a middle axle with Power Divider but NO active axle behind it for whatever reason (rear axle broke, or no spare tire thus you pulled wheels and pulled that drive shaft ... orr... you don't have a rear axle installed at all such as my case ).....
. won't power divider's differential try to send all power to the missing axle?
. To drive that axle; would one have to lock the power divider ?
... If so... too lock it do you send air to the air solenoid???.... or send NO air to the solenoid??. Not sure how that solenoid works.
..... If send it air.... anyone got an educated guess on how many PSI of air one should send it?
