Detent looks like this. That is neutral with the high rise which you have to use the handle pulled up to get over into the top notch for R. The lower selections have a low rise to slip over easy. That shifter should not go into reverse is. The handle lock is working. That is it's only purpose to prevent going into reverse without raising it If you can force it forward the spring is worn out.
Sent from my SM-G965U using TapatalkBest of luck with your tranny troubles Now it seems reasonable for a detent from N to R , but i must say there is no such monster on my shifter, I never even thought about it until some of you mentioned it , Now I wonder ?! will have to look into it !
