- 7,028
- 2,682
- Montevideo/Uruguay
Ah... so simple. One (me) would assume that a complete axle rebuild also included removing the knuckles and inspecting/servicing the king pins.The buttons were on the bottom.....
(These kind of "shortcuts" usually take their toll...
With everything correctly assembled - when pulling/pushing on the axle shaft - you should be able to actually feel some axial play. A minimum movement at least, regardless of the knuckle angle.
