- 2,951
- 7,204
- West greenwich/RI
Hello guys, I was wondering if I could your feedback as to if any of you working on the DN2M DN4M LPW2 LPW4 motors would have any interest in a compression gage adapter for these motors?
I made 2 for myself and they helped out a lot on several machines, so I was wondering if anyone else might want one?
They are machined from solid steel bar stock and fit in place of the injector, using the original injector hold down clamp.
It has an o-ring built into tip to seal it against the head ( rather than the copper washer ) and ( the next one I make will have ) a schrader valve in the tip for more accurate readings with no pressure loss in the gage / hose system.
I can make them with either a 1/4 NPT ( to accept a quick connect fitting ) or 14mm spark plug thread ( your choice depending on your gage ) to attach your existing compression gage to it.
Considering the time it takes me to hand machine one, I'd anticipate needing to sell them for about $40-50, but if there is enough interest, maybe I could have a local shop machine them for me and probably cut the price in half?
I haven't seen an adapter for these motors available commercially, but if one already exists, please let me know and I'll just keep mine and turn off the lathe!
