- 4,507
- 2,555
- East of Edmond, Oklahoma
Fled the scene and snuck back for a picture.
So underside front of truck is pressure washed?Hit a fire hydrant today in the 5 ton at 1mph today. **** thing came out of nowhere lol. Sheared the bolts clean off![]()
Sent from my SM-G930V using Tapatalk
They fit almost perfect don't they?Swapped on a 915 series battery box. The double box setup was a little too high to get out of sometimes. Had an 8d battery go bad. 3 days past its 1yr free replacement timeline. And no prorating. Just pitiful. I went to the Cummins dealer and bought a replacement 8d for 165 and a 48mo free replacement.
Yeah I put some 4x4s on each side of the batteries as I put mine sideways. This is also nice so you can actually store your cribbing in case you need it for a flat. I should have raised the box up another inch or two to match it with the fuel tank steps by the steel piece i made for the rear cab cross member would not allow it and the box actually sits half an inch off the frame rather than flush to the frame.They fit almost perfect don't they?
Without the brake pedal depressed and the emergency brake off it will more than likely be a treadle valve. Another way to test this is to just simply open your rear service gladhand and see how many lbs/min your air pressure drops versus the valve being closed or if the air vent goes away.Every time I turn off the truck, I hear air venting out of the intake too. Is this because of bad brake diaphragms?
I will get it out the door sir!Bad treadle valve for both of the above posters is the first place I'd look. Mine does it as well. When your truck is off, press slightly on the brake pedal and see if it stops. There is an adjustment possible and remedied most of my problem. Simp said he'd send me one but stays so busy that it hasn't arrived yet. I've got a new one that I lent a vendor to sell but he's still got it, I'll pick it back up from him at the GA Get together in October. Probably need to give him $20 for hauling it around over the past few years to be fair.
Is that red 12 valve turned up?View attachment 731197 seems to be more on a track than anywhere these days
