Humvee 2 piece run flat installation?
drivebymashing
51
North Carolina
I've read a ton of posts and watched videos on removing run flats. I have not seen anything on how to assemble . I know where the o ring and two pieces of wheel goes. 20180613_063755.jpg
Where does this go? Forgive me I was never in the military. I've never owned or worked on anything with a 2 piece wheel before. Thanks! !
suzukovich
141
Gibsonton Fl
I've read a ton of posts and watched videos on removing run flats. I have not seen anything on how to assemble . I know where the o ring and two pieces of wheel goes. View attachment 731570
Inside the tire with arrow facing down. Your also going to need something to compress the runflat donut to get it in the tire. Unless you have a real need for it. I would use the PVC beadlock insert and get a spare.
Sent from my SM-J727U using Tapatalk
Action
1,552
East Tennessee
From memory, that piece goes on only one side of the bigger part. One side of the bigger part has a lip. That lip hits the tire. The thin ring goes on the other side.
Action
1,552
East Tennessee
NOTE
• Ensure longer lip of runflat faces inner rim of tire.
• Ensure square cut edge of runflat spacer butts up against flat
side of runflat.
11. Install flat spacer (5) inside tire (1) and position on valve side of tire (1).
detailed instructions are in TM 9-2320-280-20-2.
