- 241
- 85
- 28
- North Augusta SC
I got my truck w/absolutely no brakes whatsoever. Upon inspection i found the master cylinder dry & vent line broke off. I found no leaks so i filled the MC & every time i press the pedal fluid squirts out where the vent line is supposed to be. The inside of the MC looked crusty like it may have gotten water/dirt in it so i replaced it. This seemed like a good time to add the remote reservoir kit so i did. The new MC bench bled easily. I bolted it to the truck & bled it at the air pack. Now i have SOME brakes, it will stop if you pump it a time or two but its not right. Do you need to have the air tanks full when you bleed this type of system? Also the TM says pump & hold then open the bleeder valve but I've always opened the valve, pushed the pedal to the floor, closed the valve & released the pedal. What yall think?
