Bed weight
brian s
holly mi
I need to pick up the box of my deuce and was wondering if anyone knows what it weighs?
Thanks in advance.
Standard 12 foot and not a drop side..
CMPPhil
378
Temple, NH
tobyS
840
IN
I read the "weight of deuce parts" and determined the bed weighs between 1200 and 2000 lbs.
Since I got some wood today to stick through it and jack it up for removal....it's good to know. Sorry, no scales to get closer. I think I need 4 barrels and the tractor front end loader can handle one side at a time.
My deuce bed becomes a dump trailer bed.
Jbulach
2,333
Sunman Indiana
Hey toby if my $.02 is worth anything to you, I would bet the 1820 LB weight quoted several time is close. My M939 14’ drop side bed with no seats, bows and the mudflaps, mudflap hangers and side marker lights removed, weighed right at 2000 LB. Unfortunately I cant find my picture of it hanging on the scale right this moment.
tobyS
840
IN
Yea, I think you are right on at the 1820# weight.
Mine has a heavy coat of undercoating that was near liquid in the heat the other day. I put 2 hardwood boards through it, sticking out the sides about a foot. I can get some steel barrels and may put a bit of water in them for stability. I picked up wood blocking at the sawmill too. Tractor can handle about 1200 so I'm okay there, one side at time.
Then the new trailer frame gets slipped under and the bed fitted to it.
tobyS
840
IN
I couldn't do that with my loader...too small. Looks like you have a serious ballast. Is that water or something else?
Bill W
47
Brooks,Ga
Water in rear tires and in 55gal drum also. My 1956 Case is a beast but I would not try this now with her.
