dronsen
- 9
- 18
- Bozeman, MT
Does anyone know the proper dip switch sequence on the back of the A0 speedometer to adjust for high speed gears? Thanks
Ok. Logical question is to consult the TM first. if that is no help. Then here we go.
I am going to assume you could calibrate it as you would a 10 switch VDO gauge using pulses per mile vs actual miles driven? Speedos all have the same if not near the same calibration per federal law. Especially these styles from what I have read. Easiest way would be a place that is certified for calibrate speedos. Since they have a roller they could put it on and do it all without leaving the shop.
http://www.nsifleet.com/pdf/OldElecSpeedo.pdf
This seems to kinda run the way it should. I don't know the exact make of the speedo on these things.
According to the TM it would 34754/35180 = 0010011010
I would start at 30341s binary and see where you stand.That's very helpful. So based on the chart the stock LMTV speedo is set at 0010011010 which is 34754-35180 pulses per minute. In my truck 50mph on the speedo is about 63mph +/- on the GPS which is a 26% gain. Does that mean we should program in a 26% lower pulses per minute which is roughly 27777 or 0010101111? Does that sound right?
I finally got around to figuring this out. Took a few hours of messing around and basically just guessing but it worked out in the end. I tried the test in the VDO doc listed above but it didn't work so I just started switching and testing. Side note... you have to turn the truck off and back on for the switch to take effect so driving around and flipping switches doesn't work.Does anyone know the proper dip switch sequence on the back of the A0 speedometer to adjust for high speed gears? Thanks
My memory isn't that good haha. I'd probably start testing 1 at a time and then different combinations of 7,8,9,10.@Rebuilder When playing with the settings did you happen to find one that indicated about 10% faster than actual speed with the 307's??? I went to 14x20 tires which has my speedo off by 5mph at 60 compared to GPS.
looks pretty much like any other differential with a detroit locker put "inside" a differential carrier.Does anyone have pictures of diffs from Bryce with the Detroit locker setup?
I tried these settings and it was about 10% low for me (e.g. shows about 60MPH at 65MPH actual speed).I finally got around to figuring this out. Took a few hours of messing around and basically just guessing but it worked out in the end. I tried the test in the VDO doc listed above but it didn't work so I just started switching and testing. Side note... you have to turn the truck off and back on for the switch to take effect so driving around and flipping switches doesn't work.
If the pics ever disappear the correct setting is 1101101001 (1=up/on 0=down/off)
I got a chance to try these out today. I tried both of my proposals above, and neither was correct. The first setting (1010101100) showed about 2x actual (GPS) speed on the speedometer. The second setting (1011000001) was about 1.5x actual (GPS) speed displaying.If we assume these switches are a binary number, for pulses per mile (or some multiple, such as this binary number * 100), we would have two options... read the binary number right to left (#10 switch is 0 or 1, #9 is 0 or 2, #8 is 0 or 4, and so on), or read them left to right (#1 is 0/1, #2 is 0/2, ...). Right to left is most common, so lets start there.
The original settings: 1101100101 = 512 + 256 + 64 + 32 + 4 + 1 = 869
High speed gear settings suggested above: 1101101001 = 512 + 256 + 64 + 32 + 8 + 1 = 873
They wouldn't really be very far apart (0.5%).
A possibility would be...
Old to new gear ratio results in traveling this much further per pulse: 3.90 / 3.07 = 1.27035830619
Cut the original number down by new gearing ratio difference: 869 / 1.27035830619 = 684.058974358
My first proposed setting: 1010101100 = 512 + 128 + 32 + 8 + 4 = 684
If we read the binary digits left to right instead (less common, but maybe they are doing it in order of the dip switch numbers, which are left to right)...
The original settings: 1101100101 = 512 + 128 + 16 + 8 + 2 + 1 = 667
High speed gear settings suggested above: 1101101001 = 512 + 64 + 16 + 8 + 2 + 1 = 603
667 / 603 = 1.10613598673
This 10% change seems more in line with what I'm seeing out of this new setting (from the picture above). It gets me part of the way there, but not all the way. So let's go on.
Cut the original number down by new gearing ratio difference: 667 / 1.27035830619 = 525.048717948
My second proposed setting: 1011000001 = 512 + 8 + 4 + 1 = 525
