cucvmule
collector of stuff
- 1,149
- 585
- Crystal City Mo
Rust Never Sleeps
Hello olly hondro, I like the tube doors. Did you use the stock mounting locationkeeping the fluids moving.
Yes, all stock hinges & hardware. Link: http://offroaddesign.com/catalog/tubedoors.htmHello olly hondro, I like the tube doors. Did you use the stock mounting location
and hinges? What about the door strikers? Thanks.
Here: http://offroaddesign.com/catalog/tubedoors.htmWhere did you get the doors?
I did the same, but used indoor/outdoor carpet with indoor/outdoor padding....-Decided to get rid of the stock floor mats I’ve had for a long time. Lined the floors with aluminum roof flashing (2.5 rolls) with rattle can bed liner on top of that.
Lowes part # 154017 for anyone interested.
Turned out great. Feels pretty durable.
Used wifey’s old floor mats on top.
It has an accy position.New GM ignition cyldylinder with accessory position for radio install( last week).
The lock cylinder does not make you have accessory position. That is something built into the switch mounted under the dash on the steering column. Just want to double check that. Make sure we are all on the same page. I think I am correct. Anyone? 99.9% sure.
Mine was the same, except that little pointer on the column tries to rip my thumbnail off even still. Mine never got much easier either- some days it pops right into ACCY and some days I have to wiggle it repeatedly.It has an accy position.
All of my CUCVs had it, but I had to convince it to go into accy, as I doubt it ever got used...Once it went into accy., I cycled a couple times and worked fine after that.....
