Question, How can one tell if they have dot 5 or dot 3 in there system? I 've got a deuce and checked the mc for the first time it was a little low so i went and bought a small bottle of Dot 5... The mc has a very light brown brake fluid in it and the new dot5 was light purple. I didnt add any because i didn't wanna find out later that i mixed it... So is there a way to tell which i have ???
First, there should be a 3x5 inch (approx) yellow label near the door for the master cylinder that says DOT5 only.
Take your finger, and dip it into the master cylinder sump, and then dip your finger into a glass of water. If it is DOT 3, the slippery feeling of the fluid will simply vanish as you rub your fingers together, and the color will disperse quickly into the water. If it is DOT5, the liquid that was on your finger will now be beaded up and floating on the surface of the water.
Also, DOT 5, from the can, has no taste or odor. DOT 3, from the can, is sweet, poisonous (a touch on your tongue won't hurt you), and smells a little like tempera (watercolor) paint.
DOT 5 comes in two colors: Purple and Yellow. It starts out purple, but if subject to DOT 3, or water, the purple color is stolen by the DOT 3, or water. Brown is a classic color for wet DOT 3... the brown color is rust from the master cylinder's cast iron body.
-Chuck
